I am looking to get the arctic liquid freezer II 240 a-rgb and some arctic p12 a-rgb fans.
I am also looking to get the msi b550-a pro motherboard.
Both the aio cooler and the fans need a 5v 3-pin connector for their a-rgb to work.
The arctic p12 fans are daisy chainable so the 3-pin connector "continues" to another fan through the one that is connected to the motherboard.
So if i plug in one of the p12 fans into the motherboard's "JRAINBOW" (3 pin) connector, could i daisy chain the a-rgb from the p12 fan to the aio?
Or does the aio a-rgb 3-pin cable have to go directly into the motherboard to get enough power?
I want to use only one 3-pin connector for both the case fans and the aio because i am looking to use the other one for another a-rgb device.
Any answers are much appreciated!
