Question Can I disconnect LED connectors from GPU without it causing trouble?
rayzeeu
14
Just a simple question here. I have a Maxsun iCraft RTX 3080 10GB. The RGB LEDs aren’t controllable and are driving me nuts. I wanted to know if I could disconnect the connectors myself and turn off the RGB that way? FYI this GPU does not have a software to control the LEDs as they are non addressable, the LEDs themselves just cycle through colours. An extra question would be am I able to purchase static white LEDs for this particular model, if so can anyone provide me with a link?
Here’s the only teardown video available on YouTube if this helps:
View: https://youtu.be/k9x8H4RcO8Q?si=4xwATF4kXqQOqil7
Thank you in advance.
there are many devices out there that don't use addressable RGB LEDs.
basic RGB LEDs were out long before and can also be controlled, just without all the options of choosing specific patterns or different colors per diode.
make sure your motherboard control software, or something else like OpenRGB, can't detect this card and offer some simple color change options.
if there is a simple cable plugged into a header, yes you can just unplug it.
it's also possible you could manually break the connection(cutting cables, etc).
but, this could be a risky process.
you can purchase a simple static color, basic RGB, or aRGB LED strip and wrap around or stick those to or in the card's housing.
but there's likely no way to just replace the existing LEDs.
Reactions: rayzeeu
An update on this. I have dissasembled the card and have removed what seems to be an LED controller board. This board was slightly hard to get out as it was glued to the logo but I got there in the end. I have ordered some 12v RGB strips and will stick that into the card when they arrive. For anyone that's thinking about dissasembling the card please note that the GPU fan shroud is very fragile as I cracked/broke a lot of the screw holes with minimal force (to fix this I used adhesive which worked quite well).
Might update further once I have finished modding the card
Reactions: JohnBonhamsGhost
