ok, so like will it fit into this cabinet? I saw the dimension of the cabinet, but not sure whether we can pull out the side panel to fit a large graphics card.
No, HDD rack can't be removed. You can buy Corsair Carbide 100R - budget case with removable middle part of hdd rack. I think it is better solution than X140.
You can also look at the NXZT S340, but it cost more. You need good ventilation for 290X.
its too costly, i mean i am totally broke after buying r9 290x, anything else, any other brand within 2000rs. I checked out the corsair 100r, in india it costs 4000rs min.
