Say I am using a Thermaltake AC0015 Dr. Power II Power Tester it says
{Designed from the ground-up to support every ATX power supply available today up to ATX12V v2.3.
Oversized LCD panel that accurately shows the value of each specific power rails (within one-tenth of a volt).
Accurate voltage indicating for +12V/+5V/+3.3V/5VSB/-12V.}
What does what number mean? +12V/+5V/+3.3V/5VSB/-12V.
Previous I though power supplies are only measured in watts and when it ages , the watt count goes down with time and making it unusable. So say 500 watt max power supplies 3 years later 450 max watt left. Now I have a feeling I am wrong.
So what number can indicate the power supply is failing , if I had the Thermaltake Power Tester
