I know of monitors with VGA connections up to 2048x1536, and I don't think your LCD will be higher than that.
VGA quality is related to the clock speed (of both the monitor and the video card). So it also depends on your video card. Check if your video card model supports the resolution of the monitor you'll buy.
Anyway, for better quality, I'd choose a DVI connection.
Rodrigo
