So My current build is pretty old and is as follows:
inteldual core 2.6 Ghz CPU
Some motherboard that is extremely outdated(i know for a fact that no current CPU can go into it)
GTX 650 TI GPU
6GB DDr2
500W PSU.
I want to slowly start upgrading everything except my GPU. I want to start with my CPU/MOBO as it will be the most exspensive. the only problem is that im on a budget and what i post later is about all i can afford. i want to know which of the CPU's would be better to get and if this MOBO is okay. Im worried the MOBO might not be okay because it is so cheap? So heres my options:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
I mainly play games such as farcry 3, BF3, Skyrim. I want a pretty good computer to run these games smoothly. And now for my second question. Which part should i upgrade next, my PSU or my RAM?
GTX 650 TI GPU
6GB DDr2
500W PSU.
