S shiotalakhadzegeorgia<3 Prominent Mar 21, 2019 24 0 510 Mar 21, 2019 #1 can i have powercolour rx 480 , i 3 7100 4 ram and mobo : h110M-K on cooto 400w ? please help
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Mar 21, 2019 #2 Can you have them? Sure if you go to the store and buy them. Running an RX 480 on a cheap junk 400w PSU is a really bad idea though. Reactions: shiotalakhadzegeorgia<3 Upvote 0 Downvote
S shiotalakhadzegeorgia<3 Prominent Mar 21, 2019 24 0 510 Mar 21, 2019 #3 thanks <3 Upvote 0 Downvote
E ElectrO_90 Splendid Apr 17, 2007 5,109 451 27,140 Mar 21, 2019 #4 I wouldn't do it Reactions: shiotalakhadzegeorgia<3 and Rogue Leader Upvote 0 Downvote
S shiotalakhadzegeorgia<3 Prominent Mar 21, 2019 24 0 510 Mar 21, 2019 #5 but can i have gtx 1050ti on this psu ? Upvote 0 Downvote
S shiotalakhadzegeorgia<3 Prominent Mar 21, 2019 24 0 510 Mar 21, 2019 #7 what is novice ? i got it Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Mar 21, 2019 #8 DO you own the PSU already? Upvote 0 Downvote
E ElectrO_90 Splendid Apr 17, 2007 5,109 451 27,140 Mar 21, 2019 #9 A 1050ti will work, but cheap PSU's are not good - but it will work. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Mar 21, 2019 #10 I hope the H110 board has an updated BIOS or it won't boot the 7th gen CPU. Upvote 0 Downvote
S shiotalakhadzegeorgia<3 Prominent Mar 21, 2019 24 0 510 Mar 27, 2019 #11 i already solved this problem i am buying 700w psu thanks for help <3 Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Mar 27, 2019 #12 shiotalax said: i already solved this problem i am buying 700w psu thanks for help <3 Click to expand... 700w what brand PSU. 700w means nothing if its a junk brand, aside from the fact its WAY more power than youd ever need. Upvote 0 Downvote
