[SOLVED] Can I mix RAM of different brands if they have the same exact size, speed, latency, and voltage?
Apr 19, 2021
56
I found a stick of cheap, used RAM on eBay which has the same specifications as my other 8GB stick of RAM. However, it is a different brand.
Would this ruin performance?
pollo5555
35
7
4,545
it could be just a bad stick of ram but if the specs are the same it should work, just as long as they have the same form factor like ddr3, speed, voltage you should be good it doesnt matter the name brand
pollo5555
35
7
4,545
I have used different brands all the time in my computers and laptops and they work great but just make sure the specs are the same as your other ram
ex_bubblehead
Polypheme
Just because it worked for you does not mean it works for everyone/everywhere. Just have a look around here at all the posts where it didn't work (Hint: FAR more than where it does work). Throwing in the randomness of something grabbed off of Ebay tilts things very much to the "won't work at all" side of the table.
pollo5555
35
7
4,545
USAFRet
159,536
12,731
176,090
24,410
When mixing RAM, there are only 2 possibilities.
Either it works 100%,or it does not.
We've seen both outcomes.
There is absolutely no way to say "Yes it will work"
Reactions: ex_bubblehead
