OK, hear me out.
I have an exceedingly roomy case with a bunch of ARGB fans in it. They're large, slow moving and exceedingly pretty.
I'd like to install an off the shelf AIO in my case, but I can't get one with matching ARGB fans, and the fans that I have are not suitable for use with an AIO.
Can I mount the radiator with its existing fans behind my pretty case fans in a push\pull configuration?
I have the space and I can machine up mounting brackets pretty easily, so it's physically possible to put it there.
Will doing so be a bad idea from a performance perspective.
And yes, I simply don't want to change my aesthetic as I've got a very customized system that is as previously mentioned very pretty.
