Ok I have a Dell XPS system with P4 in it running at 2.8GHz...
I was wondering if i can overclock it, because you cant usually overclock stock systems... but then when I took my old burned mobo to shooting range, I noticed that its a foxcon,
so I started to wonder if I can overclock it, and if its really worth it, because Its a P4, and its AGP system,
My biggest worry is passive heatsink architecture which is built like a windtunel (2 120mm fans blow all the air out the back with cpu closed by plastic cover to create airflow)
