can i play high res audio on motherboard onboard sound?
Oliverng4Ng
19
it know it may sound dumb, but can the motherboard's onboard sound play high res audio (flac); or do i need a dac/amp? also do the headphones matter in terms of playing it (i have ath m50x if that helps)
also can my samsung note 4 play high res audio?
my mother board is MSI FM2-A75MA-E35 if it help
Everyones ears are different. Your ears are not my ears.Your ears are not their ears.
You may end up spending several hundred $$$, and still not be able to tell an actual difference.
Your best bet is to maybe borrow some headphones, and maybe a sound card. See if there IS a difference, and if that is something you need to invest in.
when i play it, it wont work in itunes, so i used vlc media player. Im not an audiophile so i cant really tell the difference but im not sure if thats my motherboard, the player or my headphones?
will a dac/amp make it better?
If you can't tell the difference, how do you know there is a problem?
thats kind of the problem, because lots of people say it sounds better; and i think it kind of does but i dont know if thats a placebo effect or not
