can i play need for speed rivals Xbox 360 4gb?
khalids007
Hi,
I bought Need for speed Rivals, just for my realization it says to install the extra HD content to proceed and when I do so it just exits out. Could you please recommend me the best solution for this.
I tried Using My extra 16gb & 64gb Pendrive to extend memory. but it asks me to install it to my system. which is just 4gb, and the game is around 8gb. Is there any possiblities of me extending the system. or can I use the xbox cloud or create a NAS or Use MyCloud to play this..?? ( I know Nas and Mycloud sounds a bad idea.. as they won't be running as fast as an gaming console would like them to work..)
I had the same problem when I bought the game, not knowing if I had a extra Drive; luckily, to my relief, I realized that mine did have it. I would recommend you buy an external hard drive as it is the most reliable way of playing the game.
BUT xbox, being made by Microsoft, will always never sell anything cheap. So If i were you, I would search for second hand hard drives which can be used.
Hope it helps! ^^
Hope it helps! ^^
