So I'm getting a new comp and the PSU gonna have a single 6 + 2 pin and a 4 pin cable. I'll be getting an R9 380 Nitro ed that requires 2 x 6 pin. Is it ok if I put the 6 pin into the one and the leftover 2 pin plus the 4 pin into the other one? Will it work as if double 6-pin was connected into it? Or I'm better off buying a SATA to 6-pin converter cable?
The PSU:
1x MB connector: 20+4pin
1x P4 connector 4pin +12V
1x 4pin 12V
3x Molex
3x SATA
1x PCI-Express 6+2
1x FDD
The MOBO will require 24+4. So I'm left with a 4pin 12V, 3x Molex, 3x Sata, 1x 6+2 and 1x FDD.
The PSU:
1x 4pin 12V
3x Molex
3x SATA
1x PCI-Express 6+2
1x FDD
