If all youre trying to do is replace the fan then all you need to worry about is the size of the fan. make sure its the same as the one you are replacing. 120mm or 140mm. However you will want to make sure the fan you are getting is equal to or more RPM than what you already have, using a fan with less RPM could cause issuesI have an Alienware Area 51 R2 liquid water cooling I got from someone. The fan is very loud so I want to replace it with a "be quiet Silent wings 3". Can I do this or will something go wrong?
ok thank youAs far as I can tell. The Alienware Area 51 R2 uses standard 4 pin connectors (unlike some Dells). As this post shows a user upgrading their unit with Corsair ML120 Pro RGB. I didn't see any mention of tweaking the pinout. But only some connectors are useful for PWM. So, read through their post for a detailed how to.
https://www.dell.com/community/Alie...y/Tweaked-Cooling-for-Area-51-R2/td-p/5505704
I'd expect the Be Quiet Silent Wings 3 to work. Also with similar results to the ML 120. As both fans have a similar noise to airflow ratio through a radiator.
https://www.techpowerup.com/review/corsair-ml120-pro-rgb/5.html
ok thanks youIf all youre trying to do is replace the fan then all you need to worry about is the size of the fan. make sure its the same as the one you are replacing. 120mm or 140mm. However you will want to make sure the fan you are getting is equal to or more RPM than what you already have, using a fan with less RPM could cause issues
Make sure to pick a best answer if you're question has been solved so others wanting to know this stuff can find it instead of making a new threadok thanks you
