I bought lenova yoga 2 13" with i5 4210 (if iam not wrong ) 8 gb .... But there was problem with fan it was extremely nosy I look at online and found the fan is normally noise. I did change the thermal past (mx-4) it did really help a bit ( before: cpu was 40-50 when load and over 50 when, After: 25-30 when load and around 50 when watching 1444p video).
The fan is 5 v with 0.45 am and I found this http://www.ebay.co.uk/itm/182144877528?euid=84f581c9c85943e8bcb2011d420835d3&bu=44279134350&cp=1&sojTags=bu=bu with 0.26 amp.
Is it worth to change the fan ? I am thinking I will get noticible battery life and more than %30 reduce noise.
If you ask what I will do with the laptop I will most likely play world of Warcraft Lich king (2009). and internet browsing.
