[SOLVED] Can i replace the 120mm fan on my deepcool gammaxx gte v2 with an iCue 120mm fan?
Feb 19, 2022
6
I would like to replace my fan on my cooler because my current one is very loud, doesnt have adressable rgb and the white cannot be turned off.
Here's one, Corsair ML120 RGB Elite,
specs: https://www.corsair.com/eu/en/Categ...Levitation-Fan/p/CO-9050117-WW#tab-tech-specs
Compared to the stock fan, it has less airflow (58 CFM vs 65 CFM) but better static pressure (2.9 mmH2O vs 2.1 mmH2O).
Another option, also from Corsair would be LL120 RGB,
specs: https://www.corsair.com/eu/en/Categ...GB-LED-PWM-Fan/p/CO-9050092-WW#tab-tech-specs
It has almost the same airflow (63 CFM vs 65 CFM), but much better static pressure (3.0 mmH2O vs 2.1 mmH2O).
Sure, you can replace the stock fan on CPU cooler. Just make sure to replace the fan with same airflow (65 CFM) and static pressure (2.1 mmH2O), or better. Since installing poorer fan will reduce the CPU cooler effectiveness.
I've also replaced the stock fan on my CPU cooler. I have Arctic Cooling Freezer i32 in use and it came with one 120mm semi-passive fan. I replaced it with two 120mm Corsair ML120 Pro red LED fans, for nicer eyecandy and considerably better cooling performance (since i'm running push-pull).
Image too (Skylake build, full specs with more pics in my sig):
