Question Can i use 2x 6pins for Rx 570 8 GB 256 bit Sapphire Nitro+ Premium?
Mar 21, 2024
Hi, i'm on my way to buy RX 570 8GB sapphire nitro+ and since i have a pretty old PC, i only got 2x 6 pins for GPU. Problem i see is that the GPU has 1x 6pin plug in, and 1x 8pin plug in. Reason im asking is, is it possible and OR okay to use 2x 6 pins for GPU to work properly? There’d still be 2 pins left for the GPU. Will that worsen the performance of GPU? Id need a fast response, thanks.
No.
Plan on also buying a quality proper psu while you are at the store.
Adapters are dangerous.
If a psu were capable of powering 8 pin devices, it would have those leads.
Similarly, if a graphics card will run properly with lesser power connections, it would have been built that way.
Reactions: fidzxy
