can i use 3 pin fans with a pwm fan hub
barbonido
11
so I ordered a cheap pwm fan hub from ebay, it arrived today and I connected it to my pc and plugged all the chassis fans into it.
all of the chassis fans are 3 pin voltage controlled and the cpu fan is pwm 4 pins, my motherboard is a gigabyte ga-b150-hd3 and the hub is connected to the cpu header and gets power from a sata power from the psu.
now the problem is that all the fans (including the cpu fan) are running at full speed.
anyone can help me solve it without the need to buy a pwm fans.
The alternative device you linked to in the post of Nov 2 at 10:25 am is not a way to connect fans to a mobo header. It is ONLY a way to give you MANUAL control (see the 3-position switch on the board?) of the fans. The same applies to the item linked by scout_03 on Nov 3 at 12:38, except that it uses a continuous knob instead of a 3-position switch.
Here's the root of your problem. 3-pin fans can ONLY be controlled by using Voltage Control Mode (aka DC Mode). Any system that uses PWM Mode will always run those 3-pin fans full speed. That certainly applies to a mobo header that actually does use PWM Mode. But it ALSO applies to almost ALL fan Hubs. Those devices normally get power for all their fans directly from the PSU, as yours...
already set the fan speed In the bios to silent. I can configure fan curves tho.
gonna try that now. will reply if it works
my cpu fan is 4 pin and is now connected to the cpu header on the mobo
all other fans are 3 pins connected to pin headers on the hub and the hub is connected to sys_fan 2 that is 4 pin (this header got both pwm and voltage control)
sh*t then I bought the wrong thing
thanks for the reply anyway
yea but I dont have an empty 3.5 mm slot (my case only have 2) and no 5 inch bay at all. but nvm I decided to go with phanteks fan hub
does it change speed automatically?
and if so then based on a pwm signal from the mobo?
those aren't available where I live from newegg.
what I need is a fan controller that can control at least 5 fans with voltage control and change the speed automatically.
Here's the root of your problem. 3-pin fans can ONLY be controlled by using Voltage Control Mode (aka DC Mode). Any system that uses PWM Mode will always run those 3-pin fans full speed. That certainly applies to a mobo header that actually does use PWM Mode. But it ALSO applies to almost ALL fan Hubs. Those devices normally get power for all their fans directly from the PSU, as yours does, and the ONLY operate in PWM Mode. That means they supply a fixed full +12 VDC to every fan on Pin #2, and then send out to all their fans on Pin #4 the PWM signal from a mobo header. But a 3-pin fan cannot use that signal and does not even receive it, so it cannot be controlled that way. Thus almost ALL fan HUBS cannot control 3-pin fans.
So, how to get those fans under mobo header control? You have not told us how many you have, but there is a relatively simple way to do this if you don't have a lot. You use SPLITTERS, not a Hub. A Splitter merely connects all its fans in parallel to the mobo header's signals, and gets NO power from the PSU. In fact, unlike a Hub, a Splitter does NOT have a cable arm to plug into the PSU outputs. There is a LIMIT, though. Any mobo fan header can supply up to 1.0 amps total to all fans connected to that one header. Same for other fan headers. Now, most common case fans consume 0.1 to 0.3 amps, so using a Splitter to connect 2 or 3 of those to a single header is OK. If you post back here the exact make and model number of your fans, we can check their specs.
Your fans can only be controlled by a mobo header that uses Voltage Control Mode. In your case if you look in your mobo's manual on p. 15 at the labels on the fan headers pinouts, we see that for the SYS_FAN1 and 2 headers the labels say that Pin #2 sends out a "Speed Control" signal, and Pin #4 sends out "VCC". This means that these two headers do exactly what you want - they use ONLY Voltage Control Mode suitable for 3-pin fans. Note that the SYS_FAN3 header does NOT do this, so do not use that one.
So, you have two headers that can do the control you want, and you need Splitters to connect all your case fans to them, bearing in mind the limit on amperage for each header. Here are two examples.
https://www.newegg.com/Product/Product.aspx?Item=N82E16812423161&cm_re=coboc_fan_splitter-_-12-423-161-_-Product
https://www.newegg.com/Product/Product.aspx?Item=N82E16812423163&cm_re=coboc_fan_splitter-_-12-423-163-_-Product
The first converts a single mobo fan header into two outputs; the second converts to three outputs. In both cases the Splitter is a 4-pin design, but that does not matter - it will work just fine with 3-pin fans. A little FYI for you: all Splitters and Hubs can send back to their header the speed signal from only ONE of their fans, to avoid confusing the header. If you look closely at the photos of those items, you will see that, of the 2 or 3 male output connectors on the Splitter, only one of them has all 4 pins, while the other is missing Pin #3. That's how this device does this little job. Fans plugged into the outputs with missing Pin #3 will never be "seen" in speed displays, but this has NO effect on the ability to control them.
