can i use a car radiator in my water loop?
jvinsnes
45
I did research quite a bit before asking this, but could not find a concrete answer. sorry If this has been asked multiple times, but please do not send hate comments. I am wondering if a car rad would do the job just as good a normal pc rad. Fitting the tubes is not a problem, as the car rad i have got the same fittings as the other parts i am going to use in my water loop. The only problems would be where and how to mount it. Also, i have no idea of how to mount fans on it... maybe a 240mm fan and some duct tape? Its 280x280x2cm. I do not know if this is overkill or if it even competes with normal pc rad. So, can i use a car radiator in a pc waterloop?
that makes more sense.that is not an automotive radiator,but rather a transmission cooler which,by the way,makes more sense.
