Can i use amd r7 370 and gtx 1070 on same system?
Jan 20, 2019
Ok, so here is the issue. Can i use gtx 1070 as my main card that sends signal trough r7 370 because 1070 doesnt have dvi-a port and i kinda forgot about that when i bought it.
Is my only option to buy new monitor, or is there some adapter to conver signal?
No, absolutely not in the way you're talking about. Could you possibly drive a second monitor with the other card after lots of crying and driver work arounds, probably. But you can't send the signal from the 1070 out of the other card
Well, it does work with integrated cards apparently.
SO, my only option is to get analog to digital adapter or new monitor. Crap
Edit: I bought VGA->HDMI->DVI adapters and its working fine for now. Thread can be locked.
