Can I use DisplayPort Male to Male cable to connect videocard to display?
AdmiralMyxtaR
23
Both videocard and display support DisplayPort, so can I use DisplayPort Male to Male cable to connect videocard to display, or do I need another cable?
If the GPU and the monitor both have Displayports...yes, you use a Displayport cable.
That's what it is for.
Well, does DisplayPort Female cable even exists then? There is mini DP F cables, but I haven't found any usual DP F, so there's only DP M?
