Can I use my current PC components in a small case build?
deltakid
38
I want to save some money and always have to travel between two countries for the next year. At both places I already have monitors and at one place I have a decent PC (i7 - 2600K @ 3.4 GHz / 8GB Ram / Nvidia GTX 570).
It is in a big tower though, so I can't carry it along when I fly. I'm happy with the specs and really like to work with dual monitors so I just had the idea to take some components and put them in a small case for mobility.
If I could I would love to have the base of a laptop (without the screen) that I can reconfigure with regular hardware and just hook up on my dual monitors. In case of size I look for something like this: http://www.digitalstormonline.com/comploadbolt.asp?id=734513&price=%24999
1. What are the most important special components I have to get for a small case build?
2. Does such a small case build make sense for the future as well? Does it come out as cheaper and easier to upgrade than getting a laptop?
3. What's one of the smallest cases I can get that is still OK for a bit gaming and video editing (nothing fancy)? The Mini ITX I saw on Youtube and that are mentioned here seem to be a bit too big for backpacks... I look for something that fits in a backpack.
Any advice on this would rock!
thinking that you want to carry it in your backpack, your only bet is to get a mini-ITX (or thin-mini-ITX) case and a motherboard or simply HTPC cases, which will lead you to use your cpu integrated graphics.
to use a discreet gpu, you have to get a larger size case which is either micro-atx or mini-itx case. they will be still smaller than a standard mid-tower or mini-tower case but, will be significantly larger than a HTPC build. so it may not be carried in a backpack as you think.
forget about gtx570, any aftermarket heat sinks, most probably your current motherboard too.
so;
thinking that you want to carry it in backpack here is a HTPC build example with a mini-itx board, and cpu integrated graphics.
depending on what you are...
aatje92
1. You need a small ITX motherboard and a small low profile CPU cooler. Also you would need a low profile GPU. (so there goes your plan i believe :()
2. It's not cheaper and easier than a full tower pc, but it is upgradable and a laptop isn't.
3. Mini ITX is the smalles you could possibly go.
deltakid
38
Thanks a lot aatje! I think that folds up my research and plans. I have an empty tower and a couple of HDs still lying around at this other place. I guess I just get the current decent budget gaming stuff to outfit it and I'll be good with spending about 300 - 400 USD. Thank you!
n1ghtr4v3n
738
so;
depending on what you are going to do, a well built notebook/laptop maybe a better choice for mobility if you have cash to splash.
CPU: Intel Core i7-2600K 3.4GHz Quad-Core Processor ($284.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z77N-WIFI Mini ITX LGA1155 Motherboard ($118.97 @ Outlet PC)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory ($57.99 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Disk ($229.99 @ NCIX US)
Case: HEC ITX200B HTPC Case w/200W Power Supply ($59.99 @ Amazon)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.98 @ Outlet PC)
Total: $769.91
(Generated by PCPartPicker 2013-05-22 09:13 EDT-0400)
good luck.
n1ghtr4v3n
738
yea this was a good article, i remember :D
Latest posts
