[SOLVED] Can i use ryzen 5 3600 with gt710 GPU for programming?
May 30, 2021
4
I am planning to buy ryzen 5 3600 . I will be using it mainly for programming and movies only. I can't spend more in expensive GPU.
If i use GT710 GPU, will it work properly? will the GPU slow it down any way?
Sure you can use it.
The main limitation on a 710 will be the number and size of the displays. You couldn't run three 4K displays for example.
