[SOLVED] can i use the speakers separately? (front center surround speaker system kenwood KS-706H)
sioni90
7
(can i use the speakers separate?)
currently i have these kenwood speakers, they are a surround 5 speaker set. the question is can i use the 2 small ones for my television and the 2 bigger ones for my computer. using
2x pyle 120x2 amplifiers? the small speakers is almost the same as the big speaker except it only has 1 woofer.......
same wattage on the small speakers also. can i use the speakers separate? or would it decrease quality ?
im trying to ditch the center speaker cuz i dont have a stand for it and cant wall mount
i could either get 2 pyle amplifiers or two edifier 10" 1280 speakers.....
speaker manual specs
https://www.manualslib.com/manual/1317372/Kenwood-Ks-706ht.html?page=4#manual
thanks
thanks
The speakers are 8...
thanks
The speakers are 8 ohms according to that manual. The should be usable with any amp.
Reactions: sioni90
