Can I wire 2 4 ohm dvc subs and 1 4 ohm svc sub together and a 2 channel amp
hysellshawn18.sh
2 kicker comp vr 4 ohm dvc 12" subs and 1 kenwood KFC-W3011 4 ohm svc 12" sub on a 2 channel autotek 3500 watt amp campatible with 2 and 4 ohm
If you are using a mono bass output to both channels of the amp then you can hookup both voice coils of one kicker in parallel to one channel and one voice coil of the other kicker in parallel with the Kenwood to the other channel.
That would maintain a 2 ohm load to both channels of the amp. Not sure if the result would be would be better than just using the Kickers. More isn't always better.
