[SOLVED] Can Noctua Fan be used on Cooler Master Heatsink?
It can, but you need to find a way to mount it.
That coolermaster cooler has like, bars that hold the fan on the heatsink.
Noctua fans connect using little wires, which might not fit the heatsink. also, the fans don't come with those wires I think.
Mounting is not an issue, these bars on my current fan can be unscrewed and installed on the Noctua, my main concern was compatibility.
If I make this change I won't need to go into BIOS or anything complicated like that right?
