Hi! A few weeks ago I notice that my old generic 17-inch lcd monitor (native resolution=1280*1024,vga and dvi support only) was acting strange. First, the screen is getting covered by flickering purple pixels; I eventually fixed that by replacing the dvi cable. But then, a week after the monitor is having problems again. The display is having static lines like a TV with bad signal reception and then eventually it would turn on and off. I rolled back then updated my display drivers but eventually the remedy that worked so far is lowering the screen resolution to 1024*768. Anything higher than that and the problem starts sooner or later. What seems to be causing this problem? Is it my monitor, graphics card or my power supply?
My pc specs are (not the best of parts by the way)
AMD FX-4100 3.6 ghz
Gigabyte ga-880gm-usb3l
amd radeon hd 4250 integrated graphics
generic 600w psu
4gb ddr3 ram
I am on a very tight budget right now so the last thing I want is to buy any replacement parts. So, if i can still do something to have it working like it used to, i would be very grateful.
AMD FX-4100 3.6 ghz
generic 600w psu
4gb ddr3 ram
