So i decided to buy i5 8400 and gigabyte auros gtx 1060 6GB.And idk which motherboard to buy and whats the diffrence between the expensive one and the cheap motherboards and what gigabyte motherboard do you suggest for 1060 6gb
There are some things to consider when buying a motherboard.
1. Will it support my CPU
2. Does it have all the features I want
3. What form factor do I need to fit my case
4. Does it have the right connections for what I want to attach.
If you tell us what case you have we will be able to work out the correct form factor so it fits in your case. Also let us know what other hardware you have so we can make sure the motherboard will have the right connections for you. Also tell us what features you need such as wifi.
For psu I want to find some decent ones but hard on that website. See if you can find Corsair CX450/550
okey thanks i will check them and btw do you have something like discord or steam so i can contact you easier, to ask your few more questions.
mdd1963 :
My Corsair CX600 watt PSU was but $50 or so...it only semi-modular, but, then it is not as if I'd ever NOT need the 24 pin and CPU 8 pin connected anyway. It is also whisper quiet.
mate.stanojkovski :
mdd1963 :
ah bro i cant find Corsair CX600 in my country maybe some cooler master PSU or some other
vapour :
Nah, CX600 is old green labeled junk. Grey labeled CX450/550 is much better newer model. Any seasonic or evga psus? Or if you can list a bunch you can find, list them here with price please.
Yes, by all means, pay $30 more for a CX450, good call....
MERGED QUESTION Question from mate.stanojkovski : "Is it better to buy 1060 6gb with i5 8400 or 1050 TI with i5 8600k"
mate.stanojkovski :
So this pc i will use it for mostly gaming i am not going to overclock them so what should i get?
Jamie_69 :
8400 and 1060 will give a far better gaming experience
SgtScream :
Hands down the gtx 1060 6gb. What resolution monitor do you have?
MERGED QUESTION Question from mate.stanojkovski : "Can somebody help me?"
mate.stanojkovski :
Whats better to buy for gaming i5 8400 with 1060 6gb or i5 8600k with 1050 TI i am not going to overclock them and mostly use it for gaming so what to get?
Is this HDD good for gaming and its really cheap its like 55 euros in my country, i find HDD from Western Digital Purple Surveillance which is 2 tb with 5400rpm and its 18euros more
clutchc :
I'd have to see a link to the exact drive to know for sure. But from the specs you provided, it looks perfectly fine.
MERGED QUESTION Question from 27matej.stanojkovski03 : "I have 1 question can somebody help me about PC"
So i started building my gaming pc and about the ram diffrence in price between this rams its really small like 5 euros, 1 is 3200mhz and the other is 3000mhz but idk which is better i know that 3200mhz is better but they are not the same and they have some diffrences and ns is better when is higher od smaller? So which is better not only in mhz and other things
DIMM 8GB DDR4 3200Mhz Kingston CL18 HyperX Fury Black and the other DIMM 8GB DDR4 3000MHz Kingston HyperX XMP Predator CL15 HX430C15PB3/8
Barty1884 :
What are you looking to pair this memory with?
Some tasks/applications will benefit from tighter timings (CL15 rather than CL18), but most will benefit more from the increased speed (especially Ryzen platforms).
Each appear to be single DIMMs, opposed to kits. a 2x4GB kit of comparable timings/speeds should outperform a single 1x8GB in the vast majority of situations (and always, for Ryzen)
