I IEscobedo Prominent Aug 4, 2017 1 0 510 Aug 4, 2017 #1 I habe a windows 8 hp lap top but screen is broken and i have sony window 7 thats missing charger and battery are either of theae two compatible with eachother?
Solution getochkn Aug 4, 2017 Totally depends on many factors like volts of the battery and amps and if the jack is compatible. The battery won't fit, almost sure of that
getochkn Polypheme Jul 2, 2006 12,406 54 65,040 Aug 4, 2017 Solution #2 Totally depends on many factors like volts of the battery and amps and if the jack is compatible. The battery won't fit, almost sure of that Upvote 0 Downvote Solution
