Can sound cards improve mic quality?
Oakley999
289
Right now im using onboard sound. I have a siberia v2, the mic is pretty good, I've followed a few tutorials to make the most out of onboard sound for my mic, like using recording volume at 15 and mic boost at 30+ seems to do the job. However, Are there any sound cards out there that both improve sound and improve microphone quality? Thanks
basically, it all boils down to compatibility. If your mic is really bad, even on onboard no sound card can save it. If your mic is really good with a really bad sound card, then a better sound card will make it sound awesome.
Does anyone recommend a good sound card that improves both mic and audio quality? anything thats better than onboard will do. I have an asus P8Z77-V if anyone knows generally what kind of quality that motherboard gives.
The sound differences in DX11 and 9 are pretty slim. The only difference I experienced is the sounds are more real (If an explosion happens on the left a very long distance away, the sound comes from the left and is faint and muffled.) So if you're willing to sacrifice this then you're probably good on the card you have.
alright, will the xonar dx be alright with a siberia v2? ive heard that some sound cards mess up the sound because of some headphone amp or whatever, something like that, apparently the line of xonar dx cards are also home theater, so it sounds like they wont be so good for headsets, as my speakers are usually hooked up to my xbox one, and i tend to have more private conversations on the pc with my headset.
