Can The CPU Going Over Its Maximum Speed Cause It To Freeze?
ntechsystems3100
Ok. So Me And My Bro Both Have Laptops And My Brother Continues to have Issues With His Computer Freezing. According To The PC, It Says Its Maximum Speed (CPU) Is 2.10GHz Yet It Will Always Stay Over The Limit Given. Is This Normal Cause I Don't Want His Computer To "Fry" Itself. The Computer He Has Is An HP Pavilion Touch Smart 15-b129wm Sleekbook Running Windows 8 And Has 4GB/Ram. Please Help.
Your laptop should stop itself from damaging itself, Run an antivirus to check for problems. and if that does nothing. It might be your RAM is filing up to fast so try to close some programs.
My Brothers Computer Has Norton Antivirus And Since I Restored It (Wich Didnt Work At All) It Has An Issue With The Installation. Will Windows Defender Work As Well?
