Question Can the MSI B450M Gaming Plus have 3 case fans and a cpu fan?
Mytic
Commendable
Oct 23, 2019
51
For my upcoming build i'm looking to add 3 case fans as it's a case with good airflow. I was wondering wether i would be able to fit all 3 case fans on and also the cpu fan as it only has 3 fan headers. Is there anything i can do?
Reactions: bencos2018
To clarify... there are two case fan headers and one CPU fan header that allow independent control through fan curves you can set in BIOS.
But using splitter cables you could put two, maybe three, fans on one header and control them all simultaneously. When doing that, pay close attention to the maximum electrical load the header can handle. Each header should handle two 120mm fans OK though, three are likely but four you really have to know the specs first.
