M Millennium_Falcon Commendable Mar 18, 2016 6 0 1,510 Mar 18, 2016 #1 Can two gtx 980 tis power three 2560x1440 monitors @ 60 FPS running minecraft at high settings. If you need to see pc specs follow this link to pc part picker https://pcpartpicker.com/user/Deez_nuts/saved/
Solution stavrosmast Mar 23, 2016 There is a huge difference from minecraft and those other games... Yes I believe it will be powerful enough but it also depends on your settings.. http://www.tomshardware.co.uk/answers/id-2773368/980-sli-power-triple-1440p-monitors-ultra-settings.html http://www.tomshardware.co.uk/answers/id-2691489/nvidia-gtx-980-triple-monitors.html http://www.tomshardware.co.uk/answers/id-2695892/1440p-triple-monitors-sync-single-980.html https://linustechtips.com/main/topic/384257-single-980-ti-for-triple-1440p-display/ https://linustechtips.com/main/topic/398631-performance-gtx-980-ti-triple-1440p-monitor-setup-but-just-1-for-gamming/ Read these and Come to a conclusion... But yes it will work depending on the game/settings But for the...
stavrosmast Honorable Apr 7, 2015 2,385 3 12,160 Mar 23, 2016 #2 I hope that you are kidding about the minecraft right? Upvote 1 Downvote
M Millennium_Falcon Commendable Mar 18, 2016 6 0 1,510 Mar 23, 2016 #3 i am not kidding about the minecraft, and i will also be playing other games such as cod aw and cod bo3 and battle field 4 and hardline Upvote 0 Downvote
stavrosmast Honorable Apr 7, 2015 2,385 3 12,160 Mar 23, 2016 Solution #4 There is a huge difference from minecraft and those other games... Yes I believe it will be powerful enough but it also depends on your settings.. http://www.tomshardware.co.uk/answers/id-2773368/980-sli-power-triple-1440p-monitors-ultra-settings.html http://www.tomshardware.co.uk/answers/id-2691489/nvidia-gtx-980-triple-monitors.html http://www.tomshardware.co.uk/answers/id-2695892/1440p-triple-monitors-sync-single-980.html https://linustechtips.com/main/topic/384257-single-980-ti-for-triple-1440p-display/ https://linustechtips.com/main/topic/398631-performance-gtx-980-ti-triple-1440p-monitor-setup-but-just-1-for-gamming/ Read these and Come to a conclusion... But yes it will work depending on the game/settings But for the future you would ideally need 2x980Ti Upvote 0 Downvote Solution
Brayden Kelly Reputable Mar 21, 2015 83 0 4,660 Mar 30, 2016 #5 No it wont, 1 980 ti for 1 1440p monitor, you will need 3 for 60 fps 3x 1440p Upvote 0 Downvote
R ricks3xs Commendable Jul 21, 2016 1 0 1,510 Jul 21, 2016 #6 Absolute rubbish... I have 2 980ti in sli. With that I run one 4k screen and 5 27in prolites at 2560/1440 with absolute ease.. Upvote 0 Downvote
