Can VGA display 1080p quality with HDMI cable?
RinchenT
47
Hello,
My monitor itself is LCD 1920x1080p, however, it is currently plugged into my PC. I want to connect my Xbox as well but without the hassle of having to remove cables from my PC. Therefore, my monitor has another port which allows VGA cables to be connected. My question: Can I connect my Xbox and use an HDMI cable to stream HD gameplay?
Check your xbox's video output settings.
"Quality" is a very open term, you might as well say "it looks bad"
Are you saying the resolution is low, refresh rate is low, colors are off, what is the issue, I need specifics to begin to help you.
Also model number of your items would be quite helpful, you have not even said if the xbox is a 360 or xbox one.
You can connect your XBOX via hdmi and your computer via vga.
You will need to set XBOX to output to other speakers though
VGA will be reduced quality (you can do 1080 resoluiton) but it wont be as crisp and bright wiht your monitor.
A different option would be to get an HDMI switch with remote.
You mean, have a cable that has HDMI at one end and VGA at the other? No, that won't work.
VGA is capable of handling 1080p, but it's an analog signal, whereas the HDMI signal is digital. There is no adapter that you could use to convert VGA to HDMI cheaply. You need an active converter that requires its own power.
I have the HDMI cable now and I have plugged it into the monitor.
It works, but it isn't HD as my TV. Is there a way to solve this? I tried fiddling around with the options but the quality just isn't the same.
Sorry, I must have worded it wrong.
The high quality resolution that appears on my TV is not similar to when it is on my PC monitor even when I have set the Xbox to 1080p & I have also used a HDMI cable. When I switch my monitor to my Xbox, it dislays a message ssying HDMI, although the quality is not as good as when it is displayed on my TV.
