D dannyzfreedman Mar 10, 2018 33 0 30 Mar 16, 2018 #1 I've been browsing solutions to my issue but none have been decisive. MOBO: Gigabyte ga-ab350n Gaming Wifi. Case: Thermaltake Core v1 ITX Case Thanks!
Solution C C Calvin7 Mar 16, 2018 page 25 of manual Fan headers have fool-proof insertion key for 3 or 4 pin fans. Smart Fan 5 Settings Fan Control Mode [Auto] Lets the BIOS automatically detect the type of fan/pump installed and sets the optimal control mode. (Default) [Voltage] Voltage mode is recommended for a 3-pin fan. [PWM] PWM mode is recommended for a 4-pin fan.
DRagor Polypheme Jan 23, 2017 9,097 813 65,440 Mar 16, 2018 #2 Yes, you can plug 3 pin fan into 4 pin header, and the other way around works too. Gigabyte boards have fan autodetection so it should work plug and play. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Mar 16, 2018 Solution #3 page 25 of manual Fan headers have fool-proof insertion key for 3 or 4 pin fans. Smart Fan 5 Settings Fan Control Mode [Auto] Lets the BIOS automatically detect the type of fan/pump installed and sets the optimal control mode. (Default) [Voltage] Voltage mode is recommended for a 3-pin fan. [PWM] PWM mode is recommended for a 4-pin fan. Upvote 0 Downvote Solution
