[SOLVED] Can you remove a pin in an rgb header and it work?
definitely will not work.
you can get a regular 4-pin RGB strip that can do different colors and patterns
you just won't be able to sync them with your other components.
you can also buy an aRGB hub like the Lighting Node Pro that will sync your fans and strips through Corsair software.
Could you link one please? I found something like this: https://www.amazon.co.uk/Deepcool-R...eywords=4+pin+rgb+strip&qid=1617232200&sr=8-5 but it is only one colour that you can change,instead of loads of different ones.
