hi guys and gals,
might be getting a corsair h60 (2018) 120mm aio cooler soon,
the fan it comes with tends to be loud and it doesn't look the best, will I be able to use my sp120 rgb pro fans on this aio cooler as it means I get to keep my rgb set up and also it will be quieter.
tech specs
stock h60 fan;
airflow-57.2 CFM
static pressure-2.08 mm-H2O
sp120 fan;
airflow-52 CFM
static pressure-1.45 mm-H2O
my current case has decent airflow and temps are good but want to get some better temps on my cup hence the decision to get an aio cooler
case is a corsair 220t
if not what fan would be best to go onto the aio cooler, ideally black body but not too fussed and must be 120mm and have icue compatibility
many thanks
tech specs
stock h60 fan;
airflow-57.2 CFM
sp120 fan;
airflow-52 CFM
many thanks
