Question Cannot boot system and CPU led brighten when the fan's wires pluged (both 4pins and 3pins)
Aug 27, 2020
5
Please help: My computer cannot boot and cpu's led on mainboard brighten when I plug the fan case (both 4 pins to psu and 3 pins to mainboard).
Explain:
The 4 pins plug to PSU for fan and fan's RGB LED power.
The 3 pins plug to Mainboard for control/sync RGB LED color.
The computer can turn on to windows if I just plug one of them:
  • when I just plug 4pins to psu, computer turn on normally, fan and rgb led work, but cannot control/sync Rgb color.
  • when I just plug 3pins to mainboard, computer turn on nornally, fan's rgb led work and can sync color, but fan does not work.
Problem is not from the fan because I change several fan already.
I am using
  • MB: Aorus B450 Elite
  • CPU: R5 2600
  • Ram: Kingston HyperX RGB
  • VGA: MSI RX 570 4GB
  • PSU: Corsair GS600
the fans is coming with this case:
https://tsunami.co.th/collections/c...ered-glass-argb-gaming-case-ablaze-argb-fan-6
e7dwG3B_qn6UeYjZnejMBuN5oOOFO7xI1DncUTxdKE5kyVs0CWGvFaL248f4Sxe5MHHOihLG9lMmElBgPr4tN2V11M5PMwzaJhiqV_YS8uBvTiZ6qTUvgfV67dcYLye70Ub5BJfNW5PYZHteD0fd9JngkiUiBSBogJ3n0BnxkUM5J8SeiB4BrLAKzTe54rzpGOvEyom1GIXt5EWMH4epa_2oE8mPIehEFWNGj5OWCH0lvxyEmMM8xf-Y3vZGnaw8zSr-NnCYTi33l3VoFmW8GoEYnT86aTBHr-54YjgcOC_7boVREsFfxZSmNh9y2dojh7pfAPAreOIMRkEoHujQMZkCa9PyeFFR0oz90hTRZ8qbRkoK9x3jSpeeWdzlIJTxZDeUnaL9SlWUhXfT2dQCfajEr1K-sByPpEgB2UPN4DvZr4sIWqlyWghYr893zbjgXhQrbXLb-R828L5dOdJyEjxR6hQbHTI4RuT1WGc5GOqo1OpvLEhuwD5Wi7w1Sjwq1YyqEDtWDVPIOZ_O803J7KJC3MV-pa6aEM04TeGBM4lC2OpdM4x4dBBCoUNsBZ5Mu7b-8nJGxVv4aV7cJYofGABwj_mhWXofHVtnYrOfw6oIsQUpVCkZrn5MA3AlHWB5b6of7YkWU_mLh_NPGOODl3Laya3jo2JNda2ogdv6aQxhL8SrqSgFIh4Z4J4u-Yo=w1232-h800-no
UXAdVzkxZR9rcT8JKZg3Jnmi3BQmQGX5fN7AlAg09uFLdre1lesreaawW4EZncXeChFVgegeZGHdz5EU9P4henVrtSqXqPm4OkSxvsY-wraVfngiT-vUNnRPnzCiau7KdBFyiu296gvqxCvRscFd4lTzAb8udCXeX3kZRMGpLYUcEss-K3Wr8NhzBJnbLj4ABg3kD0wu6LyssRjPh-swIVf14smGTAC4ZpRWF_F0lfUB1jA6BTLYBghJtWmnIoxrvOII_nBGn6OzyzztiNWIc0DP7vwPhTJoZ8L18aZTOLTU8G3uWRvSiXM75N9ycAMDotSh6_jdSWHvbBvauxfSTuVV2Ek0Rik3obzJPn7xyCzjDDMRStOYiVBDMNjlVA4B8OwocDk71UJ0MvT-QutqJR1r6qDn-qApOtxjv-slPgi9LxK2WnCJqESezkkwx1psCDRHoegkvNW2mBjPjSTDDwdifvg74yuxlNcaedQSgo31VaZCJffeF7aNnbRvzXYuV9eXpgCmrhwPB6fSVpJeWhtTLHJ0Pjqxs0_FMBeYYR184G6u4ixNuzc1QAm54QbV8AefH1AW0b2vBvhVnLWEp8PQJa1033XUkzCu4T5AzrParTp9f1vXfUtdrmCdUTwNY3r4HiDGEk8-bpFhA_QZX4MxzsL0yJGdXkIjV9buJUOwu7vnKzhV3AwdllOzoa0=w378-h446-no
I do not understand, what you mean with above. I only know, that on motherboards there are fanheaders for CPU and CASE and additionally RGB-headers ( either 4-pin 12V-header for rgb-strips or aRGB-headers).
RGB-headers: only 1 color selectable( for whole rgb-strip f.i.).
aRGB (adressable RGB): every LED can be selected with different color
I do not know, how fans are connected to PSU. please explain.
Obviously your motherboard does not have aRGB-headers.
  • 1 x CPU fan header
  • 3 x system fan headers
  • 1 x CPU cooler LED strip/RGB LED strip extension cable header
  • 1 x RGB (RGBW) LED strip header
  • 2 x digital LED strip headers
  • 2 x digital LED strip power select jumpers
Hi, thanks for your reply.
I mean: The fan come with 2 wires:
  • 1 molex to connect with the PSU
  • 1 3pins 5v to connect with mainboard
The fan is coming with the aRGB, they said it support RGB Fusion on Aorus mainboard, and my mainboard support RGB fusion too.
As I mention in my first post, when I plug 3pins wire to mainboard (without molex 4pins pluged), the RGB color can control/sync in RGB Fusion program.
