Cannot Figure Out The Positive and Negative Side Of My Motherboard's Front Panel Connector
ariwebdev
25
Hi,
I have asus h110m-a/m.2 motherboard and going to connect the front panel cables of the case onto it, but I can't figure out which one is the positive side of the mobo's pins because some signs are not printed on the mobo.
Especially for the power switch, reset switch and speaker.
I had consulted to the manual book, but it is only saying that they are front panel and there is no detailed explanation.
I know the + and - side of the cable.
May someone here could help me.
Best Regards,
Ari
but some oldmen said that it can harm the motherboard if the + side of the cable is connected to the - side of the pin. that makes me worry.
