Cannot install top exhaust fan in cabinet ..
souvikray123
99
I have the cooler master k380 and I saw this image --->
https://www.google.com/search?site=&tbm=isch&source=hp&biw=1600&bih=754&q=cooler+master+k380+vozforums&oq=cooler+master+k380+vozforums&gs_l=img.3...15786.20868.0.21065.28.17.0.11.4.1.252.2337.3j13j1.17.0....0...1ac.1.32.img..11.17.1730.Jjmnq8JjkWE#facrc=_&imgrc=WDu5TbYTvWLrBM%3A%3B9vGMujoWJC1lcM%3Bhttp%253A%252F%252Fnq1.upanh.com%252Fb4.s31.d2%252F401bed4ba2f7877cdcd0cbfc25016120_49492731.dsc00294.jpg%3Bhttp%253A%252F%252Fvozforums.com%252Fshowthread.php%253Ft%253D2973350%3B1632%3B1224
So , I thought of trying it out myself but then I saw that there isn't enough room .. The RAM holders are getting in the way ... Now , my other option is to get slim fans but I dont wanna go that way coz they are sh** .. I have the gigabyte h87m d3h motherboard ( mATX ) .. So , any idea how to fit the fan like that ... Also , externally fitting a fan will disrupt the charm of the chassis .. However , that might be my final option .... Still any help or ideas would be gr8 ..
Here are my questions for you:
1. The picture you linked to doesn't show what you are describing. What do you mean by "the RAM holders are getting in the way"?
2. Can you take a picture of it?
3. What is the size of the fan you are trying to install? Is it the fan that came with the case?
I tried it but I can see that if the fan starts rotating then it will hit the RAM holders ... I think it will not be possible ( or atleast quite difficult ) to install a normal fan there and I wont go with the slim fans ...
