Hi,
My build is as follows:
Intel i7 4930k @ 4.5GHz @ 1.36v
Rampage IV Extreme
Corsair Vengance Pro (Model Number: cmy16gx3m2a1866c9) 16GB (2x8gb, running currently at 1.5v @ 1600mhz)
The Corsair ram is supposed to be running at 1866mhz, but I can't run it at that. I changed it manually (as well as using the XMP profile), but it causes way too many problems. What happens is that when I run it at 1866mhz, all my programs that use a lot of memory close after 10-15 minutes (photoshop, games like battlefield, video editing like vegas pro) and if I start the program again, I get the bsod. However when I crank it down to 1600mhz, none of the errors occur and it works perfectly. No bsod, no programs crashing.
I ran memtest on each individual rams and it showed 7000 errors once, so I restarted the test and this time it showed no errors. I then took each ram and I ran the test and no errors.
Am I supplying the wrong voltage to the ram at 1866mhz? I'm running it at 1600mhz and it's perfectly fine (been on for 5 hours now no crashes or bsod). I am in the process of doing an express RMA with Corsair but I'm wondering if it's just a voltage problem?
Rampage IV Extreme
