I took the WiFi card (Intel WM3945ABG) out of an old IBM T60 laptop and bought a mini PCIe to PCIe x1 adaptor and screwed the card in it. Then I tried putting it in x1 slot and downloading and installing the 77MB file from here then I downloaded the 25.1MB file which is the actual driver from that same page and ran it but it won't open, it just runs for a small amount of time and closes itself. I am running Windows 7 Ultimate 64bit SP1. In device manager I get it like this
I also tried with x16 slot which also didn't work. I tried botting into safe mode with networking and running that 25.1MB driver but the same thing happens. I do not know the exact model of the PCIe adaptor so I think it's the unbranded one (around 5 dollars) but it was new. I tried going from device manager->update drivers but it says newest drivers are already installed. I don't think this is relevant here because I can't even find my network but modem is Huawei HD552e (it has WiFi so I don't need a router). My ISP (which you probably never heard of) is m:tel. You can see my PC specs below. Thanks for any help.
