Can't control Bluetooth Audio
johnr283
84
4
I have a Bluetooth adapter and a Bluetooth headset connected to my pc. When the headset is connected I can't control the volume on the PC. I stays at 30% which is were I usually keep it when using my stereo speakers. When I adjust the volume control slider, the volume in the headset doesn't change. It was working fine and just started this all of a sudden.
johnr283
84
4
I went to the headphone properties and under Advanced, unchecked 'Allow applications to take exclusive control of this device. This solved my problem.
BusiedTomb
5
On windows 7, I'm unsure about other windows but i'm sure it is similar: If you right click the sound icon and choose playback devices, go to your Bluetooth headset choose properties and check the levels on it, you should be able to change the volume from there.
johnr283
84
4
Aug 10, 2019
in windows 10
in administrator command prompt,
enter the following:
reg add HKLM\SYSTEM\ControlSet001\Control\Bluetooth\Audio\AVRCP\CT /v DisableAbsoluteVolume /t REG_DWORD /d 0 /f
thus your problems will be fixed
