Question Can't control speed of pwm case fans
Feb 17, 2025
hey guys i recently bought a new case (Cougar Uniface RGB)
the case has pwm connector and cougar write on their website the fans support edit control speed
i connect pwm to SYS Fan Header on my motherboard (Gigabyte B560M H)
and i tried to go to smart fan in BIOS and the fan speed it readable As in this picture
View: https://imgur.com/a/nnQwhny
but i adjust it but nothing is happened the Fans still working at the maximum speed
help please what is wrong
Thanks for all
Specs:
OS: Windows 11
Motherboard: GIGABYTE B560 M H
RAM: 2x Crucial 8GB 3200Mhz
CPU: Intel Core I5 11400
GPU: AMD RX 5700 XT
PSU : Bitfenix Formula Series 650W 80 Plus Gold (NEW)
STORAGE: 2 HDD(Western Blue) AND 1 M.2(HIKVISION)
4 Fans bundled with the case
No Adapters
From what I'm reading off of Cougar's site, the fans bundled with the case aren't PWM.
You might want to pass on a picture of how your PWM hub is wired.
https://cougargaming.com/fileadmin/downloads/USERS_MANUAL/Uniface-RGB_usermanual.pdf
According to this manual of your case, you will need a PWM fan hooked to the port labelled #7. This particular header should be the only one that's of a different color(white, I think, while all the other connectors are black on that hub).
Reactions: bx88
More information needed:
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Attached peripheralsl?
Fans (six or more?) : makes, models, placement, ARGB/RGB. 3 or 4 pin fan connectors?
Any adapters?
Reactions: Lutfij
Thanks for replying
So what did they mean when they wrote this?
View: https://imgur.com/a/kBJlYXX
here is picture of a PWM hub
View: https://imgur.com/a/k03skNW
so the problem is the fans bundled with the case aren't PWM ?
and if i get a PWM fan and connect it to the port labelled #7 the problem will be solved and i can control speed all the fans?
Any adapters?
UPDATED
i have to say the fans isn't pwm it's 3 pin fans so because that i can't control the speed even when they connect to the hub because he had a Sata cable that will give it complete voltage but i need to know if i connect a PWM fan to the first port (labelled #7) that white port it can control the other 3 pin fans and i can control the speed?
please reply
thanks
