Can't figure out how to change language setting, my XP is stuck in Korean! help! anybody? please?
LilMissMopar
so i inheirited a laptop that is in Korean. I was told that it was a setting that had been changed & it was not the actual Korean version of windows. But everything I've tried so far kind of proves otherwise. Can anyone help?
i know it's a stupid problem to have but it's a problem none the less.
thanks in advance
Here is what is says under "system info"
Microsoft Windows XP
Professinal K
Version 2002
Service Pack 3
can anyone tell me does that mean it's a korean version of windows or did a setting get changed? and either way, how do i get it back to english windows.
Indeed, the "K" version is a Korean localization, though it can be achieved through tweaking the OS manually.
Download the correct language pack, and change the localization.
http://windows.microsoft.com/en-us/windows/language-packs#lptabs=xp
http://support.microsoft.com/kb/922474
Changes to the Windows registry
The K versions of Windows XP contain the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\WindowsFeatures
The following registry entries are associated with this subkey:
Value name: KWeblinks
Value type: REG_DWORD
Value data: 0
These registry entries are used to identify Windows XP K SKUs. When it is present, the KWebLinks=dword:0 registry entry identifies the Windows XP operating system as a K version.
Note In earlier versions of Windows XP, the KWebLinks=dword registry entry is not present, or the registry entry is set to a value of 1.
