Can't pin down the problem with my pc
Jul 2, 2018
5
Hello everybody,
So I had the idea of building my own gamer computer, I bought all the parts which are in details:
CPU: AMD Ryzen 5 2600X 6x 3.60GHz So.AM4
Motherboard: Asus ROG Strix B350-F Gaming AMD B350 So.AM4 Dual Channel DDR4 ATX Retail
RAM: 16GB (2x 8192MB) HyperX FURY schwarz Single Rank DDR4-2133 DIMM CL14-14-14-33 Dual Kit.
Graphic Card: 8GB MSI GeForce GTX 1070 Ti ARMOR 8G Aktiv PCIe 3.0 x16
Power Adapter: 650 Watt Corsair CX Series CX650 Non-Modular 80+ Bronze
SSD: 250GB Samsung 860 Evo 2.5" (6.4cm) SATA 6Gb/s
HDD: 2000GB WD Blue WD20EZRZ 5.400U/min 64MB 3.5" (8.9cm) SATA 6Gb/s.
At first the motherboard's bios version was not compatible with the cpu I had, it didn't work so I sent it back to the dealer for a bios update. I got it back and put together all the parts and it worked, I installed Windows 10 Pro, and got it running. installed all the drivers (graphic cards etc..), I tried on a game (Fortnite), after I was playing for one hour, it crashed. and everytime I was playing it keeps crashing, arbitrary, sometimes after an hour, sometimes after two hours, I tried playing CS:GO, and it had the same behaviour, after a while of playing, it lags and get's suspended for a period. Since the parts are more than enough to run this game with no problems, I tried reinstalling the graphic driver and checking all other drivers, but the problem was still there.
I tried running the windows built in performance test (performance monitor), and I got warning messages in the report as you can see in this image:
https://imgur.com/a/EQMzeOr
I tried reinstalling windows, running benchmarks and I got very good results, I checked that all the parts are there, all the cables are properly plugged in , ran the windows disk check and the windows memory diagnostic, so it's not the rams nor my hard drive in my opinion, I checked the fans are working, the graphic card fans are working. I am really out of ideas on what the problem can be, it is very weird that all the pc's parts have poor rating since it's a new pc, new parts, and should be very performant.
Can it be a problem with the motherboard that I'm missing ? And how can I really pin down if it's a problem with one of the hardware parts?
Any help would be greatly appreciated, I am out of any ideas..
If it was the RAM it will behave the same no matter where you place them.
It might be a damaged RAM slot on the motherboard like a bent pin inside the slot or even dust particles.
I did a stress test on the cpu: max temp was 62degrees
GPU:62degrees maximum
Mobo: 58degrees maximum
seems like nothing is overheating..
Thank you for the hint! It has now 7 successful passes with no errors, should I leave it test more, or go to changing the motherboard ?
What I finally did is, I removed one ram, and the windows warnings were gone, put that same ram into another slot, and the warning was still gone, so now I just test out the previous behaviors and crashes, if they're also gone, that means the problem is def coming from RAM.
Thank you for your answers.
