Hello,
I recently purchased a new pc, with a new hard drive and installed windows xp. I pulled my old hard drive (WD 500GB) to try to use it in the new machine. I had partitioned that hard drive into C:/ and F:/ drives. When I tried to install it (SATA) I found I couldn't access. I purchased an external ATA to USB cable, but still can't get it to work.
The drive starts to load, but then drops off. I am not sure if there is a conflict when the new machine reads the C:/ drive designation on the old drive (conflict with current C:/ drive) or if there is some other disk error. The disk powers up and spins. No clicking. I would consider changing the board on the drive if I knew that my problem was not a drive conflict or something else that might be fixed more simply.
I would appreciate any advice.
