Cant run nfs hot pursuit 2010 even at low settings
minimum req for the game is a c2d processor at 1.8 ghz. This would be just playable with lowest settings. Though your gpu is good enough, your processor with low clock rate is hindering you. Nfs hot pursuit 2010 is playable at 1366x760 resolution with max settings on a c2d 2.2ghz with 2gb ram and the same gpu as yours.
