When i start power on computer it ask me to replair computer i can't do something my keyboard I see Caps lock and Scroll lock blinking, when i press anything Scroll Lock is flashing. I need help with that please, thank you.
I can't check computer in desktop cuz it keeping won't let me recovery or anything, It windows 7 and i don't know what it is HP or Dell or something cuz i custom bulit it, I really smart with it but i don't know one problem is CAP lock and Scroll lock blinking.
Has anything been spilled on the keyboard? Have you tried another keyboard? Turn the system off disconnect all usb devices(except mouse and keyboard) and turn it back on, do the lights still blink.
yep i tried all and disconnect all usb, tried other keyboard, i believe it problem inside something computer
another problem: I can't do any keyboard to select whatever i choice.
**Windows Error Record**
Windows failed to start. A recent hardware or software change might be the cause.
If windows files have been damaged or configured incorrectly. start up Repair can helpdiagnose and fix the problem. If power was interrupted during startup, choose start windows normally
(Use the arrow keys to highlight your choice.)
Launch Startup Repair (recommended)
Start windows Normally
Seconds until the highlighted choice will be selected automatically: ##
Description: Fix problems that are preventing windows from starting.
*****I can't move choice from my keyboard, cause (Caps Lock and Scroll Lock are Blinking) When I any key, Scroll Lock is flashing when i buttom*****
Press del to enter setup and correct the date and time, save changes and exit and see if it boots.
tried that, when i do take out AC line then cmos jump to 2-3 pin, 5 sec and back cmos jump to 1-2 pin, AC line on back then power on made my house Power off haha, and fixed back Power on then it still not working oh well, what so i do? :/
If plugging your computer in pops a breaker, that usually indicates a power supply failure. The power supply under volting or overvolting could also cause the other issue.
Alright, thanks for tell me to trying do something so it not working...
IT not cause of my stuff, I believe it was something accident/missing hardware or software.
