G gamer_11 Prominent May 19, 2017 3 0 510 Jul 10, 2017 #1 Capacitor got a serious scratch while installing GPU. Then i examined and was not leaking. The capacitor which got scratch is audio capacitor on my Gigabyte h110s2 mob.plz help.
Solution helpstar Jul 11, 2017 A dead capacitor won´t damage other components. Could lead to non functioning or scratching sound, if it´s one of the "golden" capacitors.
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Jul 10, 2017 #2 Well audio capacitors on modern day motherboards are solid caps actually, there is no liquid that can leak on the inside. Upvote 0 Downvote
G gamer_11 Prominent May 19, 2017 3 0 510 Jul 10, 2017 #3 Then should i buy a new mob. Or if i keep using the same mob will it damage or kill my any other parts. I am poor guy and wanted to join PCMR. Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Jul 10, 2017 #4 please take some pictures of it and upload it to a free image hoster post the link of it Upvote 0 Downvote
G gamer_11 Prominent May 19, 2017 3 0 510 Jul 10, 2017 #5 But just tell me will it be serious problem. Could it kill my other expensive components. I tried booting up pc and it booted up fine. Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Jul 11, 2017 Solution #6 A dead capacitor won´t damage other components. Could lead to non functioning or scratching sound, if it´s one of the "golden" capacitors. Upvote 0 Downvote Solution
